Confused.. | on ElectriciansForums
Discuss Confused.. in the Australia area at ElectriciansForums.net
O
OhmSweetOhm
Might just be getting myself lost and confused but wanna know...
If I've got 2 seperate rooms with 2 lights in each and I use the same supply to feed the 2 rooms (from DB to light 1 then light 2 in the first room, then from light 2 to light 3 and light 4 in the second room), and I want a switch in each room, do I just pull a switch wire in to either light in each room? I'm thinking that if I do that and with all 4 lights using the same supply, both switches will switch all the lights.
Looks confusing there but I'm sure you'll get what I mean? Will someone clear this up for me please? Thanks!
you loop from light to light as you say, switch wire 1 to light 1 , switch wire 2 to light 3. then from light 1 take a switched L and N to light 2. from light 3 take a switched L and N to light 4.
Reply to Confused.. in the Australia area at ElectriciansForums.net
Did it work?
Double pole switches? Mounted on a grid module? Ignore the fact they have a N stamped on them. Or is your 2 gang switch decorative, and you...
