P
paulgault
Hi, i'd appreciate some advice on the wiring in the ceiling roses in my bathroom as i can't figure out how they're wired up as they don't seem to be wired up in the normal way!
i've done a few electrical courses but i don't work in the industry.
i'm doing my bathroom and have got some new fittings for it i'm going to replace the existing ones with.
it looks like the bathroom used to be 2 separate rooms (bathroom and toilet) that have been knocked into one. presumably it used to have 2 lamps with independent switches but now it has just one (SP) switch controlling both bulbs.
when i first took the cover off i was a bit confused as the lamps appear to be connected between the live feed and the switched wire and are not connected to the neutral. this didn't seem to be right so at first i thought there was a polarity issue, with one of the red blocks actually being the neutral.
i've got a decent voltage indicator that i've used to check for a voltage between all the connectors and the results aren't making any sense.
they've got the 3 standard connector blocks in it.
-on the left are 3 black and 1 red wire. there's no voltage between these wires and earth when the switch is in both positions so i've assumed this must be the neutral, but there is no connection between here and the bulb.
-the middle has 2 red wires (and another to the bulb). there is a voltage between these and earth when the switch is in both positions.
-the right has 1 red and 1 black wire along with another to the bulb. these have voltage between them and the earth depending on the switch
here's what it looks like
there are 4 twin core and earth coming into the ceiling rose. presumably the feed in, the feed out, one to the switch and another to the other lamp.
does anyone know what is going on here. help would be very much appreciated
thanks
Paul.
thanks
Paul.
