connect 2 lengths of 25mm cable together | on ElectriciansForums
Discuss connect 2 lengths of 25mm cable together in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
J
james1
hello whats the best way to connect 2 lengths of 25mm square cable together
would be pos to use henley blocks. what if i use cooper tube crimps and heat shrink insulation
frankly you could twist them together and use chewing gum, but do you want proper advice????
Can't see the point of joining meter tails...can you enlighten me?
Ahh ..are you trying to hide the joint ;-)
Reply to connect 2 lengths of 25mm cable together in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
totally agree
dreadful, I couldn't sleep at night after that install, it may just about pass but the quality of work is substandard IMO
