V
vincentv
I have a motor which is 3 phase. The power connection has 4 wires which is L1,L2,L3 and E.
And the power source we have is a 5 connection supply which has L1,L2,L3,N and E.
I accidently connect the E wire to N of the supply, and turned the power on. The cause the workshop power supply to tripped. After turning on the main supply and do the connection correctly. E connection of motor to E of supply the motor is not working.
Just wondering what i did, by connecting the motor E wire to N supply has damaged the motor or burn the motor?
Cheers
Cheers
