connecting 4 x 6mm feeds | on ElectriciansForums
Discuss connecting 4 x 6mm feeds in the UK Electrical Forum area at ElectriciansForums.net
A
Adam Smith
Hello all, just a quick one.
Could someone please recommend a suitable way of terminating 4 6mm 3 core cable in a weatherproof junction box. I was thinking 60 amp connector block but don't really like the idea of trying to jam in 4 conductors and have them all held on the same screw. My other idea was some sort of insulated busbar (like an SP henley block, only more slim line) that can be neatly tucked away in the (probably rather large) junction box.
Any thoughts? All input is appreciated.
Cheers
depends how big your box is already (if you have one) if not use an adaptable din rail box with wago top jobs should do the only point i make is make sure you have an easy point of isolation
Thank you for the responses. The DIN rail idea does look the neatest and some of the DIN modules look interesting, but I think the WAGO connectors are best for the time frame I have (tomorrow afternoon!)
It's a temporary site office hook up to 3 units. Usually I would just loop in and out to each units main iso, but these units have a male commando plug to connect to on the outside (with isolator) so do not have that option. So my plan is to run an armoured to the first unit and just spur off of it with 3 separate feeds.
Reply to connecting 4 x 6mm feeds in the UK Electrical Forum area at ElectriciansForums.net
I've made the required tweaks on the junction box with a 4mm hole bottom, upturned wagos and reduced the exposed copper. I did originally install...
Hi Richard, thanks for your comment. The relay is rated 12A peak. It's also worth noting that a relay contact will perform differently depending...
    • Winner
