Connecting a hob | on ElectriciansForums
Discuss Connecting a hob in the UK Electrical Forum area at ElectriciansForums.net
C
chrissysmagicbo
hi i would just like to know about this... have a hob which requires a cable of 4mm to hardwire to cooker switch. the fuse at board is 30amp and the shut off near the cooker is a 45amp. as i cannot find a 30amp switch. my question is, i have no idea what amp or size the original cable is although it has its own circuit, which comes from the main fuse box, is it ok to use a different size wire ie 4mm and yet the original house wiring is, say 6mm. my real question is can i use 4mm for the hob as i have no idea what cable is used coming from the main switchboard. does it matter if i use 4mm wire as suggested in the manual? hope you can understand my question, thanks for any help, chris
hi thanks for your help, well as the maker specifys H05 RRF 3 CORE X 4MM i will use it as stated. the set up previously was a cooker switch with a socket. the standalone cooker was hardwired into cooker switch but had a spur which went on to a double socket which had small appliances ie kettle. as this was a radial circuit??? i removed the spur. so now have just a cooker switch with socket. the oven is single with a plug and the ceramic hob is the one that must be hardwired into it. the hob is 6kw. and i have a seperate fused cooker switch that turns off the hob and oven.the hob is about 1 meter away from switch. i gather this is all in order? chris
Are you suggesting fused as ,"at the consumer unit",or local ?
I mean there is a fuse just for this supply on fuse box of course and also a fuse in the cooker switch which is about a meter away from hob and cooker. hope this is what you are asking. please ask away if you dont understand i know i dont explain myself very well. so cable comes into kitchen from fuse board that is where i have the fused cooker switch. then i have a cable which comes from the fused cooker switch and ends at the original "cooker switch with a socket" which is accessable. the oven is plugged into this and i will hardwire the hob into it. i thought that it would be better to have a fused cooker switch which i can turn off after use. previously the cable went straight into the cooker switch which wasnt fused and also had spur running from it. thanks chris
The fused cooker switch seems to be a bit of a strange animal
[ElectriciansForums.net] Connecting a hob
It's not something like this is it
so cable comes into kitchen from fuse board that is where i have the fused cooker switch. That is the picture I posted I guess Chris
then i have a cable which comes from the fused cooker switch and ends at the original "cooker switch with a socket" which is accessable.So from the swich you go into a cooker switch
the oven is plugged into this and i will hardwire the hob into it.That mate is where if I read everything right we have to stop, as you can't do that.
I can only advise now Chris that you may have things slightly confused, and it is difficult to explain things on a forum I agree. But the very fact that your confusing things, and may be telling us what you are is because really the work is a little beyond you.
I can only advise for safety sake you ask for help. post your general location and i'm sure one of the lads could come round and give you a quote for the work you need done
Reply to Connecting a hob in the UK Electrical Forum area at ElectriciansForums.net
I actually did it with a 4 core 4.0mm swa last week!
Suggests yes, but doesn't prove it, not all imperial cables were tinned.
davesparks
