Connecting bath drainage to soil pipe Hi all,
I need to connect my bath drainage to my new soil pipe. I have only one spare entry to boss into the pipe at the very bottom (see photo). As the inital entry out the wall will be on a gradient I was wondering if there was a combination of elbows I can utilise to get a 90 degree vertical drop down to the entry point? As I'm using 50mm pipe I'm not sure I can fashion something on an angle, similar to boiler condensate pipe the other side.
Or would it be easier to just employ a strap boss further up the soil pipe?
Cheers. P
Connecting bath drainage to soil pipe to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Cheers. P
