K
kester_holmes
Apologies if this is not the right place for this post.
New build extension with electric Warm Up brand underfloor heating in 1 room; about 6m which I think is only about 750w. Electrician connected temporarily via an 13A fused switch (there is also a circuit breaker on consumer unit). There are L, N & E wires coming from consumer unit and same L, N & E from heating element/col. The switch has 6 terminals and connects mains to heater wiring, so activating switch turns heating on (obviously ).
I want to replace the switch with a programmer to switch heating on and off at certain times, or may have to connect programmer in series with switch. The programmer (Sunvic TLX 6501)has instructions for standard 2 wire connection; says connect Live to terminal COM, and heater to terminal NO.
Could someone help me understand the appropriate wiring I need.
My thought is to join (via appropriate connector block) the mains Live to heater live, and same for mains earth and heater earth. And then connect either end of the heater Neutral to programmer terminal NO and mains Neutral to programmer COM. Presumably the circit would then be normally OPEN, but become complete and pass current through heater coil when programmer activated (i.e. ON time occurs)?
Can anyone tell me if this is the right approach?
ta
Kester
ta
Kester
