Hi,
I have been asked to fix a problem with a pond pump.
The existing setup consists of an outdoor water resistant outlet that the pond pump plugs into, but the socket and plug are in a concrete box embedded in the ground and covered by a slab to look like part of a rockery. When the drain hole provided gets blocked (and it will get blocked again) and it rains, the socket and plug are flooded.
There is no way to guaranteed the compartment will not flood again, so I believe the best way forward is to replace the current socket and plug with a permanent IP68 connection, but I can only find glands for SWA that are IP66, so what do I use to connect SWA to flex correctly in an environment that may flood?
Any advice will be very much appreciated,
Many Thanks
Paul
Many Thanks
Paul
