Hi guys,
Been doing a kitchen install as I mentioned a few weeks back.
Oven circuit is run in 6mm T+E to a standard DP cooker switch and then in the same again to a flex outlet plate below.
Stupidly I'd forgotten that the integrated hob directly above needs a live feed for the ignition!
Can I run both flexes from the outlet plate? (with difficulty I assume)
