Connecting wall mount | on ElectriciansForums
Discuss Connecting wall mount in the DIY Electrical Advice area at ElectriciansForums.net
spjonesuk
Worcestershire
Ive bought a atf600 wall mount with transformer attached. Details on transformer are input 230v output 4.2v 600ma. Question is I have a unused fused spur where I want to put this could I connect it to the fused spur if so what fuse would I put in the spur.
Many thanks
Yes, and 3A.
The power module can be fitted in a 47mm deep plastic back box behind the programmer wall bracket.
If you're not planning on doing that, the module really needs to be in an enclosure to provide adequate insulation for the mains connections.
Yes, and 3A.
What size cable would i use to supply the transformer from the fcu?
Reply to Connecting wall mount in the DIY Electrical Advice area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
That worked!!! Thanks again for all the help and responding so quickly. Really appreciate it!!!
