Connections in consumer units. | on ElectriciansForums
Discuss Connections in consumer units. in the Electrical Course Trainees Only area at ElectriciansForums.net
Simonslimline
South West, Bath
When say adding a new circuit to a DB/CU do you tend to check all the connections in said DB/CU are sound and tight!
I have come across a few boards recently where pretty much every cable is loose including the main tails literally just sitting in the switch, but no signs of overheating etc, so not much load on them i guess.
Either people are not terminating them properly in the first place or they have loosened over time. I cant see how they can loosen so much though to be honest.
I think maybe the quality that goes in to manufacturing some of the equipment these days also plays a part in this, IE cheap tacky boards/switches etc.
Just thought i would ask as it seems to be a reoccurring situation i see.
Yes, and I also checked for temperature with a thermal imagery sensor
terminations can be made tight at the time. over a few hours/days, these can become loose due to copper creep. always best to re tighten after wiggling about.
I'd say you should be checking the tightness of all the terminations every time you have the cover off a CU for whatever reason, not just installing new circuits. As you say inferior quality components and the expansion and contraction of the copper over months or years often leads to loose terminations.
I think Pete has it right, the price of a Flir camera nowadays is pretty low and I'd suggest one should be standard kit for sparkies even in the domestic environment.
You have given me an excuse to purchase more tools now.
I will have a look in to them. :)
Reply to Connections in consumer units. in the Electrical Course Trainees Only area at ElectriciansForums.net
