Sparky_Ben
What is best practice for adding 2-3 sockets in a new build conservatory? i am also putting a light in there but that can be fed from an existing outside light which would fall on the inside of the conservatory,
Any help on wiring techniques? and i take normal t+e is acceptable no need for swa etc?
just break into the ring and extend or fit a fused switch at 13a and take a radial into the conservatory! you can also then wire the light up from the radial via a 3A unswitced unit to a light switch to give light (or just use another Switched FCU if you want rated at 3A
T/E perfectly OK. as durham says, 13A FCU off ring for sockets.
conservaroty wiring,
Thread Tags
Sparky_Ben,
telectrix,
