M
mars6394
Hi all i have recently just picked up a conservatory to wire ie normal riong main setup/lighting.The problem is he has a pond pump,pond lighting and outside lighting,
The client wants the pond pump and pond lighting on one switch which i am going to install a fcu switched onto the ringmain but he wants the outside lights on there own switch seperate from the pond pump/pond lighting.
Am i in the right to add 2x fcu next to each other providing they are supplied off the ring main and run 2x armoured cables supplying lighting,pump 1x to outside lighting.
or shall i just put the pump/lighting on the fcu unit.and run a 1.5mm from the main lighting point and joint up outside to the armoured supplying the outside light
many thanks if you could help me with this as i seem to have baffled/confused myself thinking too into it.
