Construction Sites Wiring Site Cabins | on ElectriciansForums
Discuss Construction Sites Wiring Site Cabins in the Australia area at ElectriciansForums.net
Y
yawnee
What type of cable should be used for site cabins on construction sites?
i would imagine that not many cable types would be suitable for the possible mechanical damage that could occur on building sites.
The site mains would hardly ever be inside a portacabin but elsewhere on site within an enclosure. therefore a cable suitable would need to be run over ground or buried (SWA in both cases) or via catenary wire (SWA again due to fork lifts or other lifting equipment). i would suggest that there would only be only very few cases that anything other than SWA could be used. namely if two portacabins were absolutely next to each other and a supply was needed from one to other. the gap between such unit would of course hae to be very small otherwise you would be considering SWA again.
Hope this helps. as i said before it wuld depend on the site circumstances. i am not aware of much in the way of changes from the 16th to the 17th with regards to sites, but i am ready to be corrected if someone has details.
Do cabins a couple of days a week and only ever SWA to cabin CU then standard T&E inside. Don't settle for anything else than SWA, and even that doesn't protect against everything. Try running a dozer over a cable and see what happens!
Reply to Construction Sites Wiring Site Cabins in the Australia area at ElectriciansForums.net
Yes, that was actually something making me uncomfortable too, the bonding of it all. I need to have another look at it, I'm not sure if the...
I use this one, copy this into a search engine: 200EP Tone Generator Kit High Accuracy Cable Toner Detector Finder Tester with Inductive...
