Hi all,
I am going to do a consumer unit change in a mates house and use this as my assesment job, and hope you can clear up some points for me.
mouse
- Do i need to use a domestic electrical installation certificate or would a normal EIC do?
- I intend to place the CU directly on the wall with a length of trunking on the top side of the unit and drop the cables through slots directy into the CU, and the tails taken in through the units cut outs on the bottom, Would this satisfy the IP requirements IP4X for the top and IP2X for the bottom?
- This is the long winded one! A spark has repaired a cable in the dining room by chopping the plaster and jointing the cable with choc block and covered the hole with a single socket outlet no back box just the socket sitting there doing nothing, my mate wants a proper repair doing and the hole plastered but this cable is not in a safe zone, have suggested putting in a socket to create one but he doesnt want this, do i note this on EIC? as i thought only PIR could have fails!
mouse
