Consumer Unit Change | on ElectriciansForums
Discuss Consumer Unit Change in the Australia area at ElectriciansForums.net
Depends on your budget really, however, Hager, Contactum, Wyles are good.
You may be better off installing a 5+5 dual rcd split load cu and spread the circuits over both side to comply with the latest regs.
Reply to Consumer Unit Change in the Australia area at ElectriciansForums.net
You can definitely connect a grid-tied solar system to a consumer unit in a shed that's fed from the main house's consumer unit, but there are...
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
