consumer unit change | on ElectriciansForums
Discuss consumer unit change in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
5544
have to move a consumer unit 6 feet and upgrade. normally i use a generic water proof terminal box (200mmx 305mm)and install the correct loading contact blocks to continue the rings and radials to the new location.
what do others use.
Another part of the question though is what's trying to be achieved by moving the CU. If it's because it's going to be in the way, then what's the point of replacing one box for another? Especially when you still have to get back into it for inspection purposes (screw terminals). Another option is inline crimp/shrink in trunking which achieves the same thing with less bulk (though not as sexy to look at or put together).
Reply to consumer unit change in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
M
I meant EIC, No idea why I put EICR down, thanks for the clarification
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
I have to agree with Baldelectrician on almost everything he says except one ! I wouldn’t be walking away I’d be running lol. Definitely if your...
