E
electek
Hi All,
I've got a brand new wylex consumer unit which has mains incomer switch (non rcd) feeding 2 a 6a RCBO's , 2 x 32A, MCB and 1 x 40 A MCB. Then also it has 5 MCB's ( 2 x 16 A , 2 X 6A and 1 x 32A) FROM A 30mA RCD.
My question is i'm going to use this as an assesment piece for Elecsa but will is this considered a 17th edition board or do i need it to have two 30mA RCD Units ? I'm thinking if i RCD everything that should be RCD'd through the 30mA RCD and put the upstairs and downstairs lighting on seperate 6A RCBO's then this would be ok.
Also two other questions :
does the consumer unit have to have an on/off switch as well as RCD
What are the un RCD'd breakers for ( 2 x 32A and 1 x 40 A)
Thanks in advance for any help.
