Consumer Unit Knockouts ( Garage) conduit incline | on ElectriciansForums
Discuss Consumer Unit Knockouts ( Garage) conduit incline in the Australia area at ElectriciansForums.net
hi there
after some advice re fitting a metalclad cu for a garage rewire. the wiring will be in 20mm pvc conduit.
Now when the 20mm conduit is fitted to the knockouts(x2)it is just over 6mm away from the wall, they then run to 2 T boxes 250mm above, now i cant offset for just 6mm so i have run them both straight with a small incline. looks really neat and tidy. i only ask as this job is part of my assessment for elecsa so dont want any silly mistakes.
any thoughts would be very much appreciated.
i thought of using packers/washers but then realised all the conduit boxes/switch boxes/socket boxes further down the line would also be 6mm off the wall too which im not too keen on. do you think the slight incline is wrong ??
Push a thin strip of 6mm ply behind the adaptors so they become verticle , heat up the conduit with the wifes hair dryer when plyable push another piece of wood up against the conduit and hold for a short while whilst the condut cools this may well give you the double set you need
Double set the conduit and cut to length
Warm up the conduit and press fit
Washers behind the terminal boxes
Fit ply behind the cons unit
Just about every sensible idea has been given and each one is a practical solution
Now, a not so sensible one, in case you cant make up your mind
Drill your own holes
Reply to Consumer Unit Knockouts ( Garage) conduit incline in the Australia area at ElectriciansForums.net
