Which consumer units have left main switch?
Discuss Consumer unit left main switch ? in the UK Electrical Forum area at ElectriciansForums.net
Space and access. of the unit I need to replace. Thanks for your inputMK produce left side switches whereas others are predominantly right side however MK stopped producing consumer units but are still available under licence from a producer in China, why do you ask.
I'm pretty sure the old Wylex ones had the switches on the right?As above the Crabtree "starbreaker" seem to fit your bill and is decent enough gear.
What are you actually replacing? If it is a "modern" CU then probably not much of a space issue, but if it is one of the old Wylex style of rewirable fuse boxes then nothing made today is as compact.
If you care to post a photo or two of the current setup folks might have more advice. Redact any readable personal information on stickers, etc, first though.
Reply to Consumer unit left main switch ? in the UK Electrical Forum area at ElectriciansForums.net
