C
currie123
Hi , I doubt there will be a regulation against it but is there a maximum distance in a domestic property between the cut out and meter and the fuse board for the flat? Currently in a flat iv been at there is a redundant storage heater board beside the meter and main cut out which will be ripped out but the domestic lights and sockets etc are supplied from a board about 15meters away. This board is supplied by a 16mm split concentric cable which I have been advised is okay. Not ideal for flat fuse board to be 15meters from the main fuse etc has anyone seen a set up like this before?
