Consumer unit mounting | on ElectriciansForums
Discuss Consumer unit mounting in the UK Electrical Forum area at ElectriciansForums.net
I have read that the consumer unit needs to be mounted on non combustible material,
what do you do in the case of a consumer unit replacement when the old one is fitted onto wood, chipboard, mdf etc that also has all the dno equipment fitted, on an older property, the original cu or fuses etc would have been fitted onto plain old wood
you read wrong.
It's too late to get the book out, but i'm sure that these roumors come fram way back when there were CU's out there, and still are, with open backed enclosures - wylex's etc, you still see loads of them.
Something about any switchgear likely to produce arcing etc.
Modern boards are not 'likely' to produce arcing unless under fault conditions.
As i say, too late to go digging so i'll leave my hat on.......
Reply to Consumer unit mounting in the UK Electrical Forum area at ElectriciansForums.net
Same as above, if the property is old which your posts suggests i would definetley get an EICR first incase to see what conditon the installation...
