T
TerryH
Hi All -
Regarding our present domestic electrical installation, I haven’t touched our consumer unit for 47 years - yes it is correctly fused. So today I checked out the CU, and find to my horror I have only three fuses in the unit, two 30 amp one wired for the cooker with 7/044 T&E, one ring main with two lots of 7/029 T&E and one 5 amp fused with Twin no earth 3/029. I worked for an electrician when I left school at 15 until 17 and I still remember the oldcable sizes even now, although I am a retired service engineer ( best job I’ve ever had boys – retired that is).
My chalet style semi detached house and was built in 1960and consists of a ground floor and first floor. I would like to have installed a PV system comprising Sanyo HIT-H250E01’s with the Enecsys micro inverters into a FITsystem. There are no spare ways in my CU, fishing on the internet for information, leads me to believe that I will need amodern CU with split domestic wiring, and dual RCBs with an MCB to each circuit to conform to edition 17 regs.
Is there anyway within the over solicitous and bureaucratic electrical safety and building regs that you lot have to put up with now - that would allow a qualified and certificated electrician, to just fit an additional CU for connection to a properly installed MCS FIT system?
Your advice will be greatly appreciated. Regards Terry
