Consumer Unit Replacemet question ;) | on ElectriciansForums
Discuss Consumer Unit Replacemet question ;) in the Australia area at ElectriciansForums.net
1shortcircuit
If you had 2 Wylex 5way RCD Consumer units spare in your van along with some Henley Blocks and a Double Pole Main switch and enclosure etc would you install these instead of a 10 way board that you don't have in the van?:cool3:
Installed correctly so that both boards can be isolated at the same time I don't see any issues with this :D
:thumbsup
Reply to Consumer Unit Replacemet question ;) in the Australia area at ElectriciansForums.net
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
