J
jonboy79
Hi all,
So i was thinking about running a consumer unit from a spur for all the outdoor pond stuff. I wanted to have in there 3 Rcbo's at 6 amp, 1 for the pump, 1 for the led lighting and another for a water feature. None of these go past the 6 amps. They will only be used for this and nothing else, and wanted them to be protected and isolated with there own tripper, so say the lights go, the pump won't etc. The CU has about 10 feet to where i will be picking up the power. Will this be ok??
Many thanks
PS was going to run, spur > RCD > extension lead. But couldn't find anything that would be a mcb, unless you know of anything like a plug in rcd which is a mcb. I know the CU option is not the cheapest way, but also gives me a little project on the way..
Many thanks
