Consumer unit | on ElectriciansForums
Discuss Consumer unit in the UK Electrical Forum area at ElectriciansForums.net
In addition, the maximum distance permitted by most DNOs for meter tails is 3metres. Any more than that and you would require SWA cable and a switch fuse. As above, you'll need a competent electrician to design and install this, also to co-ordinate with the DNO for the seals at the cut out to be removed and the service fuse removed, unless you happen to have an isolator already fitted.
So, not a DIY job on many fronts. Find an electrician at Home - https://www.electricalcompetentperson.co.uk
Reply to Consumer unit in the UK Electrical Forum area at ElectriciansForums.net
However it's done, you need to have a guarantee of no sharp/unprotected edges that can damage the insulation. Personally, I'm not that impressed...
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
