consumer unit | on ElectriciansForums
Discuss consumer unit in the UK Electrical Forum area at ElectriciansForums.net
T
tedglen2
I am having my house rewired. The comsumer unit is above my kitchen door. On a house rewire does the unit need to come down to 1200mm for wheelchair use? Not sure where it would go at that height.
No it does not.
If you were having a complete refurb done on the property then possibly.
The same thing goes for heights of switches and sockets. No need to change them, just wire straight to existing heights.
At the end of the day though, if you are the client then the spark carrying out your work will liaise with you and inform you correctly:thumbsup
hmmmm not sure ill have to consult the regs, but i susspect not, the fuse board is not something you should have to access as a consumer, well at least not often. and any problems/work done on it, should be done by a proffessional.
its not like switches and sockets,
There is a specific height recommended for Consumer Units but this only applies to new installations, not existing ones.
Anything old can be wired to as it was unless iirc there is to be a change of use or the property is having a complete refurbishment:thumbsup
- - - Updated - - -
one said yes and one said no : $
Which one is a Part P approved contractor?
As already said, it doesn't have to. I did a complete refurb last year, put the consumer unit at 1200 as the owner was in a wheelchair and was then told by the owner that he wanted it moved back up to almost ceiling height!!! Where do you want it?
FFS!!, a rewire is replacing like for like, a new build or top to bottom refurbishment is a different story, however the regs say, and it is a requirement of and EICR that all switchgear is easily accessible, so with the exception of nailing it to the landing ceiling, put it where you like within reason!
Reply to consumer unit in the UK Electrical Forum area at ElectriciansForums.net
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
Indeed it would be. But that would mean having 2 things to disconnect instead of one. More margin for error. Of course, any diligent spark would...
loz2754
L
