Contacting a 5 Kva generator to standard 3 pin vacuum,please help | on ElectriciansForums
Discuss Contacting a 5 Kva generator to standard 3 pin vacuum,please help in the DIY Electrical Advice area at ElectriciansForums.net
C
CLEARWAY
Hi , please can I ask your advice. I have searched everywhere for an answer and am confused.
Pin short I have bought a 5 Kva generator to power a 3300watt vacuum and I need to know how to connect the generator which is fitted with a regulator to a standard three pin socket into which I can plug the vacuum.the generator has 240 v , 32 amp socket. How do I make the connection safely , What connector type do I need that plugs into the generator , then cable size ,then whatstandard three pin plug receiver at the other end.
Please excuse my ignorance amongst you all .
any help appreciated
thanks
anthony
Hi fella,presumably,the vacuum has a blue,round "plug" attached? If this is the 32A plug you describe,it will require swapping for a smaller,16A plug.
Your generator,should have a corresponding 16A mounted socket,on a unit of that size.
If we are talking about one of our Chinese allies base model examples...buy a fire extinguisher before anything else...:goofy:
Reply to Contacting a 5 Kva generator to standard 3 pin vacuum,please help in the DIY Electrical Advice area at ElectriciansForums.net
"A catalogue of errors" would be the appropriate phrase here and I agree with Avo and James that HSE need to be involved rather than this forum...
