E
edrobbo8
Hi, looking for some alternative views on this.
Need to fit a contactor and last man out switch for a large house with 2 consumer units, each controlling roughly half of the house. They are fed from 2 separate phases from the 3 phase board.
The last man out switch will be by the front door, and I'm trying to work out how it can switch off around 6 light circuits in each c/u. Would it require 2 separate contactors, with one in each board?
Thanks.
From board 1 take a live conductor to the switch at the front door, a switch live from the switch to each of the coils of the contactors near/at the seperate c/u (you may need 2 contactors per board if you need 6 dedicated circuits) and a neutral back to board 1. Then cable the Line conductors of the lighting circuits through the contactors. Hopefully job done.
Just tell them to allow 2 extra minutes to get ready. I’ve never heard such a daft idea in my life, (well not recently).
A DP switch by the door should sort it.
Tony you are bang on! Can understand why they want one but will be a pain in the rear if they come in through the back door and have to get to the front door before they can switch on the lights!
they will want it 2 wayed with the back door I had similar question asked they wanted to turn ALL the power off at night when they went to bed I reminded them that Fridges dont like losing power neither would the boiler neither would the light the old dear when she needed a pee in the middle of the night they said "haddnt thought of that!"
Contactor for lighting and Last Man Out Switch
Australia
edrobbo8,
mogga,
