P
pjcomp
Here's the scenario:
Big house with detached granny annexe. Three-phase supply. Single phase supply by buried SWA to annexe for power and light. Separate three-phase supply by buried SWA for the annexe night storage.
The clock for the NSH is in the main house. The 3ph goes to a fused switch (three 32A fuses, big chrome handle on the outside of the box) then to a 3ph contactor, then via SWA to a 3ph CU in the annexe. Each phase goes to two storage heaters, each heater on its own circuit and MCB.
Now the problem:
The night storage in the annexe worked fine at Christmas. It was switched off after granny went home, then switched on again at Easter for the next visit. Didn't work.
The three 32A fuses had all blown.
Replaced the fuses, the night storage was switched on again. And the fuses blew again.
Nothing tripped in the annexe consumer unit. The contactor appears OK, unjammed, slides freely.
All circuits checked, no shorts, no problems found. 5a fuse for the contactor is intact. No problems on any other circuits in the house or annexe.
Any suggestions what might be knocking out the fuses? The presence of the contactor in the equation is throwing me a bit - I've not had much contact with them and not too sure why it's been used in this case as I wouldn't have thought the loading required it. Someone with more experience of them might put me right ....
PJ
Now the problem:
PJ
