Contactors with MCBs? | on ElectriciansForums
Discuss Contactors with MCBs? in the Talk Electrician area at ElectriciansForums.net
B
brannaman
Hello All,
I'm doing an installation in a nightclub soon, and am asking for your opinion on the best way to wire the following.
The club has many lighting fixtures, each requiring a seperate supply from a 16A MCB. I am looking at about 30 circuits worth.
However they would also like the facility to turn on/off the entire rig from a remote switch, and also perform staged turn ons/offs to prevent too much inrush current if all the fixtures were powered together.
I guess ideally I'm looking for contactors with built in MCBs, so that each channel can be individually controlled by some sort of PLC. If there is no such device, I need some contactors and MCBs that are suitable, and an enclosure that would support wiring these together.
I have a choice of distrubition boards. Either I'll take the three phases from the main distro and have a seperate single phase supply board for each of the phases (about 12 breakers per board), or I'll have one larger three phase unit.
If anyone can give me any ideas about the best method/product to use for this, they would be greatly appreciated.
Thanks,
David
Dave
I don't have any info on contacts your looking for but haven't you got to be careful not to get Strobescopic effects if you use a single three phase board?
Seem to recall something about lighting and three phases.
Warren
Reply to Contactors with MCBs? in the Talk Electrician area at ElectriciansForums.net
Probably a bit late for the OP, but there's a very easy option if a manual solution is OK. Rotary cam switches are just the ticket - but not the...
I may have been mistaken regarding TT I will look into that, thank you for the valued reply, but in general I stick to my post, a good topic for...
