Continuity Between P & N | on ElectriciansForums
Discuss Continuity Between P & N in the Australia area at ElectriciansForums.net
E
eskimo39
Hi I was working Xmas eve at a friends house installing some decorative faceplates to all his sockets. I turned off the power at the MCB and then when I checked accross Phase and Neutral to determine that the supply was off, got a continuity beep from my Fluke T5.
I checked this on all the downstairs sockets and got the same result. However on the upstairs sockets It showed no continuity and no voltage. Can anyone explain why??
Cheers
If appliances were still plugged in on that circuit you would get continuity through the line conductor, through the appliance and then back through the neutral conductor. You will also get continuity between line & earth if the neutral is still connected at the distribution board.
Reply to Continuity Between P & N in the Australia area at ElectriciansForums.net
Thank you, what would be the advice for me to do in this scenario? I've also seen circuits tripped in past from other things such as 1500VA step...
