Continuity readings unstable using Megger MFT 1730 | on ElectriciansForums
Discuss Continuity readings unstable using Megger MFT 1730 in the UK Electrical Forum area at ElectriciansForums.net
Sting Ray
Has anyone experienced issues with continuity readings fluctuating on a Megger 1730 MFT when the test leads rotate/move in the instrument as is the unavoidable condition when actually using the tester?
I can null the leads but thereafter the reading with the leads connected to each other can jump to anything up to 1 ohm if the jack plug rotates.
The instrument was recently sent to Industrial Services Limited for repair and calibration and returned with a statement saying in specification, no recal required and they cleaned the contacts but alas no improvement. I've tried new leads but same problem.
I'm wondering about possible dry joints somewhere behind the test lead sockets.
Megger technical have said there have been "one or two" instances of this fault and have asked me to return the instrument to them which I will do. When I get it back I'll post the outcome.
I returned my 1552 to Megger twice, when it was returned it was fine for a few weeks before playing up again. The cost of returning it and hiring a replacement was becoming a hassle, so I finally bought a stand alone continuity / IR tester.
Reply to Continuity readings unstable using Megger MFT 1730 in the UK Electrical Forum area at ElectriciansForums.net
Having some issues with my companys fluke 1662/1663 tester. Zeroing 2 leads for continuity test we get the value 0.08 which is expected. The issue...
FFS - popped it apart, found the same issue and thought I'd update... You guys were already there!
