schoe
Hi guys i was wondering if anyone could give me soon advice. I have just installed some spot lights in my kitchen and before i connect them up i want to do a continuity test. I have run the power from a circuit breaker into a junction box, then from the junction box i have run my switch wire and wire to the next light using the junction box system.
Looking at the osg it says you should test at the furthest point, i have tested at the switch and have an acceptable reading, ive testing the power coming into the junction box this is also acceptable. My question is how do you test at each spot light? Using the juction box system when you link the phase and earth at in the C/U you can naturally test the incoming power and switch as they are all interlinked but the spots lights arent. Therefore when you test at the spot light you dont get a reading like you would with a standard ceiling rose.
To test this part of the circuit would you have to disconnect the lighting wire from the junction box and test the lights separatly or is there a simpler way,
Any advice would be really helpful, regards Chris
