controler for street lighting | on ElectriciansForums
Discuss controler for street lighting in the Australia area at ElectriciansForums.net
M
milos
Hi to everybody on this forum. I'm reading you all the time and learned a lot of stuff here. Now i have some problems in the work and i need help from someone with expirience .My boss give me a three way diagram from controler and energetic unit ,and i need to conect them and draw these schemes in one way diagram.Please help me to resolve this, i need to do it but I m so confused.
Thanks.
Sorry for my bead english.
  • AmpLight3.pdf
Hi Tony...The first page on the document it's ok,but the diagram in the second page is three line diagram.That diagram i need to redraw, but in one line diagram.
Thanks.
the diagram to me is in its simplest form it shows everything clearly and is easy to follow even easy to see which contactors are required to be closed in order to power the light at different levels, i cant see how you can put this in a simpler format and still retain the information it shows, sorry but im lost as to what your trying to achieve.
<<< Confused .com Why redraw unless he is asking you to incorporate other manufacturesrs equipment or wire as something else (Which Id be apprihensive of doing due to problems mixing n matching in the past )
sounds like his boss is the one who cant understand it and has set this poor employee a head scratching task thinking it might be easy to follow if the lad re-draws it, but as i said before making it simpler as a diagram will make it harder to follow as you loose infomation (.......and information cant be lost as hawkings theory goes.)
The same words I have told to him...and my boss give me an example what he want's .He said, for showing to people I need to be more simpler and that's it. wtf??? So ,I m thinking how to make it easier for regular people ,but to be readable for electricians.Any advice to make more basic?????
The attach is the exsample of my boss.
  • example.pdf
The attach is the exsample of my boss.View attachment example.pdf
now now smart arse chaps the boy is obviously not that familiar with reading schematic drawings!
So he has came on here looking for a wee help oot!
So let's start by asking him what part of it is confusing him then we can go from there!
must be great to know everything?
Reply to controler for street lighting in the Australia area at ElectriciansForums.net
Thanks little spark. Good point but the drivers I'm considering have a sync and communication between driver function. So (as long as it works)...
Hi I'm again struggling with a long overdue 2396 project but, as before, am at a standstill when it comes to the lighting design. Please could...
