G
GK Electrical
hi
I have to fitt 6 x 2kW convector heaters in some place 45m from main fuse boar.
What is the better/ right solution?
1. run 2,5mm cable from each of them to the main fuse board and protect it with 20A mcb
2. run thick cable (what size?) from the main fuse board somewhere closer to the heaters and put there small fuse box where i will connect the heaters in?
Thank you in advance for your help..
