MangoTango
All, I'm a bit stumped trying to convert a three way traditional switch over to the Smart Caseta Single Pole On/Off switch. There are two switches today for a light, the plan is to convert one switch to the Smart switch, then add a secondary remote to the alternate switch location - essentially no longer using the wiring between both switches.
I am thrown off on the ceiling gang box that appears to feed the hot wire. See attached image overview. The switch wire White was going to Hot Black. The Light wires (both same color)... One went to pig tailed Whites in gang, The other went to Black that routed to switch box (not to the bulk of pig tailed blacks).
Caseta Single Pole switch has Black, Red, White and a Blue (not used). Manual said to connect B-B, R-R, W-W.
See attached. What is the consensus on this one to get this wired correctly?
