O
osok
Hello all.
I've been asked by a client to convert a pull-bell doorbell system (pulleys etc) into an electric one.
When the 'puller' by the front door gets pulled, the rod (below) goes out. I thought I'd have something there closing a circuit.
When the circuit is closed, I was thinking of having either a tube or rotary solenoid pulling/rotating the spring-loaded arm on the bell (below) so that the bell rings.
Using the string/pulley system doesn't work in the layout of the hallway of the property, hence an electric solution.
What I'd like to ask is, what is the best way of going about this, and if the solenoid route is good, what would be an efficient (cheap) implementation route?
Your technical expertise would be greatly appreciated. :bucktooth:
