W
WolvesJon
Hi all
Wiring up a new cooker and hob. I have put a new 10mm supply in to the cooker switch and the 10mm down to a click dual outlet plate. Hob is rated at 7800 max and instructions state use a 4mm flex. Oven is prewired with 1.5mm flex(no plug). Will i need to go from the cooker outlet to a fused spur then to the oven to protect the 1.5mm cable as this wont be protected by the 32amp mcb?
Many thanks
Jon
Many thanks
Jon
