cooker connection using dual connection plate, fusing considerations. | on ElectriciansForums
Discuss cooker connection using dual connection plate, fusing considerations. in the Australia area at ElectriciansForums.net
J
jase31
Scolmore do a 45A dual connection plate. (http://www.scolmore.com/documents/switchtoclick.pdf) that has two output connectors.
The example photo shows thicker cable as the input, and two thinner cables on the outputs. Should the mcb be rated to protect the smaller cable, or can an over/hob be connected without having to fuse down.
What would be the most appropriate way to wire a hob and oven using this connection plate.
Reply to cooker connection using dual connection plate, fusing considerations. in the Australia area at ElectriciansForums.net
