P
Piratepete
Found this on the ESC 17th Ed Guidance site.
Q35. Is a cooker switch or cooker control unit required to be provided as means of emergency switching for an electric cooker?
Generally, cooker switches and cooker control units are provided as a local means of isolation and switching off for mechanical maintenance.
In most cases, the controls incorporated in a cooker can be used to remove the source of heat if danger arises.
However, a cooker switch or cooker control unit may also be provided as a means of emergency switching if the designer of the electrical installation decides that it is necessary, in which case it must be located so as to be readily accessible.
The reason I ask is because when I came to fit a new CU last week, the free standing cooker was plugged into a socket behind it on it's own circuit!! I'd normally have asked 'Where's the isolator' but see Q35 and answer above!
Comments?
Pete
Comments?
Pete
