Cooker Hood - Advice Please | on ElectriciansForums
Discuss Cooker Hood - Advice Please in the UK Electrical Forum area at ElectriciansForums.net
Norfolk
Hi,
I am just replacing my 16 year old extractor cooker hood! Have an isolator switch and separate 3pin plug and the old hood simply plugged in. The new hood (CDA CST61) i've bought says THIS APPLIANCE MUST BE CONNECTED TO THE MAINS SUPPLY USING FIXED WIRING VIA A DOUBLE POLE SWITCHED FUSED SPUR OUTLET AND PROTECTED BY A 3A FUSE .
My question is does this really need to be fixed wired in? Or will a 13 amp plug with 3A fuse be ok as I already have a separate isolator switch?
Hopefully not a stupid question and would welcome any advice please.
TIA
Reply to Cooker Hood - Advice Please in the UK Electrical Forum area at ElectriciansForums.net
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
