Cooker hood - connection but no current | on ElectriciansForums
Discuss Cooker hood - connection but no current in the UK Electrical Forum area at ElectriciansForums.net
london
hi all,
i recently bought a flat and got a years old cooker hood in it.. which i am trying to replace..
all done but the connection inside it does not have power... tried all the switches on and stuff but still no joy..
any place where is should check .. or how to find the fault or where the connection may be ?
i have attached pics of the same.
  • [ElectriciansForums.net] Cooker hood - connection but no current
If you have a grid switch arrangement in the kitchen with multiple switches for different appliances it could be there ?
Maybe. Or it may come from under the bathroom floor, above.?
If you can't find a switched isolator and supply source, get a spark in.
hi all,
Is it plugged in
' ypu may have a duff fuse in the plug top
What does this mean? -how to check this
follow dave OCD's advice. get an electrician to sort it safely. anyone can get something to work. likewise anyone can cause a fire or electrocute some poor sod.
Ok found the actual switch beside the washing machine.. Written canopy on top of it.. Which is on... Will check the fuse thingy tomorrow morning
I'm all for DIY bro but please get a spark in. It will probably take them 10 minutes to find the problem and less than an hour all in to sort it all out. You're looking at about ÂŁ100 max.
Reply to Cooker hood - connection but no current in the UK Electrical Forum area at ElectriciansForums.net
Could you not make something? For example a thin metal sheet (aluminium for ease of working) a bit bigger than the hole (say 180 x 120 mm), with a...
Thats why somebody told you to spk to the sparky
