Hi all, and a happy Easter to you. I'm just having a quick look at someone's cooker hood, it used to work but the decorator was in yesterday and drilled the hole for the extractor and now it doesn't. Basically you can have the lights on the hood and they work fine, or you can have the extractor on the two lower settings and it'll be ok, but you can't have the lights on as well as the extractor. If you try the fan motor seems to try and start and the lights flicker.
its a Luxair extractor if that helps.
All connections at the switch seems fine and the voltage from the spur to the hood is constant.
any ideas on what it could be?
