I need to install a cooker hood. Only close supply is the cooker switch. My plan was to install a FCU next to the switch and then terminate hood, fused appropriately.
My concern was, if the cooker supply is 6mm > I think I'm going to struggle terminating 2x6mm2 cables from the supply side of the switch to the FCU.
I have just heard that there is a 3metre rule that enables you to use a smaller CSA to supply the FCU.
Have you heard of this? Could someone point me in the right direction within the regs?
If this is true then the next conundrum would be obtaining a secure connection with 2 different size conductors into the terminal...... ferrules on the hood flex will help
