Cooker Install Diversity | on ElectriciansForums
Discuss Cooker Install Diversity in the Australia area at ElectriciansForums.net
SKY
Hi All
I'm still training and wonder if someone could explain the diversity factor that can be applied when specing for a cooker install and knowing what cable and mcb to use?
Many Thank in advance
Sky
Find out total load & put to amps
Take first 10 amp.
Take 30% of remaining amps & add to the 10amp
If a socket is on the ccu add another 5amp
You now have a diversified load for circuit design.
Look in the OSG
Take first 10 amp.
Look in the OSG
and as a result you will often find that a 6mm cable on a 32 amp breaker will do unless the installation method derates the cable significantly :)
Reply to Cooker Install Diversity in the Australia area at ElectriciansForums.net
There's a church in a town near me that has solved the heating problem for most days by building what is essentially a large timber and glass...
Capping off redundant pipework question. Hi all. I done some work for someone a few years ago and I've been getting paranoid that things haven't...
sammy67
