Cooker installation first time | on ElectriciansForums
Discuss Cooker installation first time in the UK Electrical Forum area at ElectriciansForums.net
J
James has
Hello just wondering if this is correct its all working fine just want to double check
[ElectriciansForums.net] Cooker installation first time
No. You will have basic insulation visible outside of the enclosure. You should be clamping the sheath. You should be measuring and recording the Zs and rcd trip times in order to confirm compliance (safety).
ok i will correct that but are they in the right order ?
That's difficult to tell from here. The connection unit appears to be marked right to left, L, E, N. It appears you may have the connections incorrect, without being able to see the colour markings of the 'supply cable', which appears to be recent colours?
I would recommend you employ an electrician.
Reply to Cooker installation first time in the UK Electrical Forum area at ElectriciansForums.net
Exactly. I was going to ask on the earthing once he clears this boiler fault (suspect on internal component). OP mentions oil boiler but makes no...
I know it was a few years ago when LED was mor in its infancy but we looked at a job that had designer flo light fittings in a big bar. The...
