W
waldo
Hi Guys
just look for some advise, getting new kitchen fitted in a couple of weeks. new oven is a 3.5kw 16amp, cable installed in wall is 6mm, should this be ok or do i have to change it to 10mm.
The isolation switch is in a 2 gang drywall box but takes 2 1 gang switches, one is a fused stur for hob.
from the side of the gas hob i've worked out it would only be 130mm from fused stur and 200mm approx for the isolation switch, would this be ok
cheers for the advise
