Cooker keeps tripping.. advise needed! | on ElectriciansForums
Discuss Cooker keeps tripping.. advise needed! in the Australia area at ElectriciansForums.net
T
Teddy54
Just installed a new CU and everytime I turn on the hobs there fine but as soon as i turn on the oven it trips.
I have done IR test and its all clear. Really baffled here.
Anyone any idea what it may be? Its in a 40A mcb with a 83A RCD.
As has been stated, it's almost certainly a duff element - if there's more than 1, it will be the one in that part of the cooker you are switching on. Google espares, their web site is good and has videos showing how to replace an element. ALWAYS switch off the supply at the consumer unit, before attempting to check/replace a part.
Reply to Cooker keeps tripping.. advise needed! in the Australia area at ElectriciansForums.net
A kettle boiling fish - thats your fault right there... or is it a red herring? :)
It might be worth asking the customer to turn the oven on 45min before you arrive. then do an IR test on the oven from the isolator with the oven...
